Hello
I was wondering if I could use BIM objects (from websites) in VisualARQ and if they would still be editable?
I’ve seen that most were compatible with Sketchup, Archicad, revit etc.
Thank you
Hello
Thank you
Hi @marchermitte,
You can import any geometry into Rhino block and use it as a VisualARQ element. But as there is no integration yet with any of these services, you’ll need to add all BIM parameters to the elements.
The problem is that there is no public VisualARQ SDK yet, so these BIM websites cannot create a plugin for VisualARQ.
Good news is that we’re currently working on this SDK, precisely for a BIM service: BIM&CO (https://www.bimandco.com/). The SDK is going to be included in VisualARQ 2.3, planned for the first week of September. What I cannot tell you is when BIM&CO (and the rest of websites) will publish a compatible VisualARQ plugin.
Regards,
Enric
Ok, I did load objects as elements indeed but couldn’t find a way to keep their editing capacities.
I hope that some of those BIM website will take the time to make compatible meshes for visualARQ.
Another question, there are no handles in the windows of door styles, do you plan to produce more advanced and complete styles in the future, including handles and grips?
Thank you!
Yes, we have plans to add more door and windows components, like handles, hinges, latches, etc.
Enric
Estupendo!
Gracias Enric
Hi @enric,
Will the version 2.3 and its SDK work with ifc4 files?. That would be good news…
Hi @JuanExposito,
No, VisualARQ 2.3 won’t have support for IFC4. As far as I know, IFC4 is not yet supported by any major application. Neither Revit or ArchiCAD do support full IFC4. They are able to open an IFC4 files, and they support some of the new property types from IFC4, but many of the new features, like NURB surfaces, are not yet supported.
Our plan is to start implementing support for IFC4 when Revit and ArchiCAD do, as they are the applications we use to test our importer/exported.
Thanks,
Enric
Hi @marchermitte
I know this is an old post! but I let you know that we have included in VisualARQ 3 a native “Handle” component for doors and windows:
Hi Enric, is there any news about it?
Hi @Alessandro_Barbisan which news do you mean? there are different requests described in this Topic
@fsalla I wanted to check in on the current progress of the SDK, if it’s still under development. Additionally, I wanted to understand if the VisualARQ API is currently being developed. Thank you.
Hi @Alessandro_Barbisan yes, there is an API available for VisualARQ. There are some functions available, and we are expanding them on demand. A user recently documented and shared it in a post: Level of detail for different print outputs - #24 by antoine3
