Can we please make flip matrix smarter for GH2? [WISH]
Please…
Today I have spend hours trying to make this work (I finally did). But it is still baffling that I am required to use 9 components when I should be using 1 for such a simple task. Maybe I am just not good at data managing, or maybe GH isn’t good at it…I collapsed the problem into this simple example.
I have a grid of points, organized in horizontal branches, and I want the tree to be organized in vertical branches, do some operations, and then be able to go back to the horizontal branches structure.
I first tried a geometrical solution, using point in curve. Going back to the previous structure required a different approach using Create Set and Member Index. This approach proved its limits when the points are superimposed over one another.
flipmatrixpain.gh (22.9 KB)
I then tried a data management solution, looking through old threads on the forum. At first it did not work, and I was stunned for a long time, because it should have worked… but of course, Insert ItemS (mind the “s”) does not work with multiple indices, or at least not as one would expect. I revisited an old thread of mine where I noted this, but the solutions provided there did not work with this case.
Hopefully Sort List made it work.
These are the kind of things that a small amount of scripting can make light work of. With complex data there is always going to be hard times flipping and flopping the data around without iterative searches.
Hi
Have you tired reversing the list in the beginning?
edit:
this is a little bit more clear
Mmm I am surprised that works, all that is left then is to reverse the paths, with replace paths, like so:
It indeed has to do with what flip matrix is literally doing, each 1st item of each branch goes into a new branch.
Thanks!
LowerTrianguleArray.gh (12.2 KB)
