First of all, thank you for the sofware! I’m enjoying my ride learning Eto / IronPython a bit with it. Lately, I have come with a question that I don’t find a way to answer with my biased knowledge.
Say I want to mesh an specific face from a given solid and I want to specify certain points of its surfaces for the mesher to respect. By respecting these points I mean for the mesher to put there a vertex when meshing.
Is that even possible? Is there a way to specify certain constraints to the meshers?
I’m not sure if this is a coding question or a modeling question.
In Rhino, the QuadRemesh command allows you to use guide curves. In Grasshopper, the TriRemesh component has a Features input.
Thanks for your reply. I have tried in multiple times to execute that option (QuadRemesh). I’m within the trial period the a message telling me that the command is not registered appears, [Versión 7 SR12
(7.12.21313.6341, 2021-11-09)]:
Strange as I can get the following script from your resources:
Regarding code or modeling, first I want to try the UI and see if I can achieve my purpose before going into Python. Don’t know if that makes any sense to you. Hope it does.
On QuadRemesh options, I can see the Symmetric Axis thing as a possible way to solve the problem but I cannot check any options on the UI regarding that :S
Also, I am playing with the script and reading the docs (QuadReMesh | Rhino 3-D modeling) but, after placing two guide lines, nothing happens no matter what GuidCurveInfluence integer I use on the script :S
same result after perform the repair. Either way, it does not matter to me if I can call the QuadRemesh from scripting but the thing is that it seems not to be working (remeshing does not follow my direction :()
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 5-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2060 (NVidia) Memory: 6GB, Driver date: 7-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 471.41
> Integrated accelerated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2021
Driver Version: 30.0.14.7141
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\CodeListener (8c4235b6-64bc-4508-9166-bef8aa151085)\0.1.7.0\Rhino 5.0\x64\CodeListener.rhp “CodeListener” 0.1.7.0
Hello- hmmm - I would at least test it without ‘code listener’ - disable that plugiin in Options > Plug-ins page then close Rhino and re open it - does the command work now?
