Can this new feature be added !Rhino9?
Hi all
Can this new feature be added?
Hi all??
@BrianJ @pierrec @dalelear
Moved to Serengeti category
Thanks for the suggestions @Mehraneftekari ! We are still focused on Rhino 8 internally but these are neat areas to explore. Fill and QuadRemesh may help in the meantime if you need what the second and third video show.
Hi All, interesting features!
I would add a simple one from Modo, preserve curvature when adding loops
Yes, I know it can be done. There is also a Remesher feature in Cinema4D, but Rhino still requires a set flow-like command because it requires us to run the Quadremesh command every time, which is unnecessary in many cases.
The QuadRemesh request is in Rhino YouTrack
https://mcneel.myjetbrains.com/youtrack/issue/RH-78339
The InsertEdge “preserve curvature” request is in YouTrack as https://mcneel.myjetbrains.com/youtrack/issue/RH-78340
The nicer looking quad cap on a cylinder added to Rhino YouTrack
https://mcneel.myjetbrains.com/youtrack/issue/RH-78341
@Jussi_Aaltonen - can you take a look at the very first video in this thread and see if enhancing “bridge” might be one way to address the current modeling deficiency?
Looks like a fairly flexible way of defining the shape of the bridge. Of course in the case of a bridge it would require mathematically different approach because both ends are fixed. I think the bridge should probably be built by minimizing a sum of weighted error functions to add flexibility for controlling the shape. Of course matching the bridge ends would perhaps be as simple as adding some more constraints.
I added YT for getting back to this once Bridge gets some developer attention again: RH-78344 Bridge: consider new way to adjust shape by mouse and keys
What about the “fix topology”/“set flow” request.
This is the most interesting one imho, as quadremesh tends to create meshes with topological problems.
@Trav Is the fix topology / set flow request something you can investigate?
This looks like an expanded version of Jussi’s bridge tools.
A new command has been added to 3dsmax 2024.2, which is very useful
https://help.autodesk.com/view/3DSMAX/2024/ENU/?guid=GUID-3FF16AFC-3E1B-4712-B504-70BA79643CA8
Blender
spin tool
