Strangest thing that ever happened to me. I cant open my file due to very strange reason.
Basically when all the tables in the file are unreadable or missing you’re screwed…
do you think its was an error during saving or what could have happened? its a simple file with few simple drawings… i actually used bak file which was bit older and there was no problem opening.
Yep, I think that most frequently the file gets corrupted when saving somehow. I don’t know how, as the file saving mechanism is supposed to first save a temp file and only overwrite the original once the temp file has been saved correctly.
