Hi everyone, when I try to run Gh on Rhino 7 this window is popping up and then Gh window is empty. Any ideas on how to solve this? Im using a Mac M4.
Hi Elios -
Grasshopper seems to work fine in Rhino 7 on my M3 Mac.
You’ll need to run the GrasshopperLoadOneByOne
command and deny any third party plug-ins to load. When Grasshopper then loads correctly, you will need to run this again and allow one plug-in at a time to find out which one is preventing you from running Grasshopper.
Hi and thank you for the reply, even when I try to run GrasshopperLoadOneByOne same problem apears.
