Can’t connect wire
I cant connect two ends of the wire with flow along curve no matter the circles diameter… Can you guys help? Maybe give me some tips,thanks.:slight_smile:
Hi @Life_of_Lazar
In the command prompt settings, make sure that Stretch=Yes
HTH, Jakob
Edit: Or make sure that base and target curve are exactly the same length
thank you Jacob for the quick reply. My measurements were the problem. My curve and baseline lenght didnt match. Thank you so much for your reply again.
