Hi
V5
storage as 3D,
need the boxes to have edges as black lines whilst shelves and walls NOT.
How is this done ?
(without drawing box edges in and giving line thickness etc)
Cheers,
Steve
Hi
V5
storage as 3D,
How is this done ?
Cheers,
Steve
Well, it seem that you can adjust your display mode settings, copying the mode you want, and then thicken up the edges, in the settings.
if you need something 3D’ish, you can select all all the edges, duplicate edges, and then create pipes for all the edges.
If you do, you might want to group the result. I have not tried SubD multipipe for exact this purpose, but…
I did as you said, made a copy of shaded named it shaded with dark edges.
I went with the surface edge settings, 4 and got edges a lighter shade of the object colour.
Not sure how I get black but it might do.
setObjectDisplayMode and chose that names view.
However that has then only made the edges so in the perspective view,
Wish that command did so to ALL views.
One has to select the objects all over again, in each ortho view.
Steve
