Can someone verify that the Python method CurrentDimStyle is valid?
I have a dimension style that I named “Ringo”. When I use the CurrentDimStyle method in Python it is returning this:
function CurrentDimStyle at 0x000000000000002B
Can someone check this and see if it is broken or is it me doing something wrong?
Here is the code:
strDimStyle = rs.CurrentDimStyle
print strDimStyle
You could also test this (and see the same results):
print rs.CurrentDimStyle
Thanks,
Dan
Hi Dan.
Rhinoscript functions still use parenthesis, even when no parameter is supplied or when default parameter values are used instead: rs.CurrentDimStyle()
Yes, of course. Thanks for reminding me. I kind of figured it was me. :slight_smile:
Dan
Yep, you were setting a variable to a function. A very cool concept once you understand what it is doing, but also a pretty easy to hit mistake for user migrating from RhinoScript.
Just to open the variable as a function “can of worms” and make your head explode :smiling_imp:
func = rs.CurrentDimStyle
strDimStyle = func()
print strDimStyle
or
def add(x,y):
  return x+y
def subtract(x,y):
  return x-y
myfunc = add
print myfunc(6,2)
myfunc = subtract
print myfunc(6,2)
hmm…
My head already hurts! I’m a little late to the Python party and sometimes I just want to go home! :smiley:
Dan
