Can someone tell me how to fix this artifact when panning/rotating/zooming?
when I am trying to zoom in on very close corner joint, this is what happens! I can’t even see the corner!
whats making this happen and how can i fix this?
Hi Vyan - if you get in so close that the view is clipped, change the projection to Parallel in the Properties panel (with no selection). Also, use Zoom Target to reset the target for more predictable zooming.
Any luck?
changing the projection to parallel helps, but it’s hard for me to model like that.
zoom target worked
is there no video/option setting to control this?
