Hi friends,
Rhino is an advanced surface modeling software. Can a solid modeling technique create all the objects which Rhino as a surface modeling software does? (All the complex details)
Short answer would be yes in theory. They all use the same basic NURBS technology, the āsolidā vs āsurfaceā thing doesnāt mean so much anymore, āsolid modelingā used to mean that the system never ever let you do anything that left your part model in a non-closed state. Theyāre more flexible nowā¦but not so flexible to allow Rhinoās freeform point editing of surfaces, which is the original basic reason it exists.
The differences are in how the interface works to make certain tasks easier or not, what sort of specific features are included or focused on, and who itās marketed at.
Do you mean that solid modeling is missing many features and itād better to use surface modelers?
Yes. SolidWorks would be an excellent candidate. Superb filleting and excellent G2 continuity tools. One reason very many top-tier industrial design studios, but also many second-tier studios, use SolidWorks these days. And it is very affordable.
It depends on the industry sector and business segment. In some industries, youāll rather find Creo or Catia.
Iām not so sure. My local top tier car company is using Catia for construction and Creo for motor construction. Alias (early) and Icem Surf (late) for āvisibleā surfaces. Rather new is the use of Catia Isd, which is a parametric version of Icem Surf, but its not always gold which shines.
Since we split āvisibleā surfacing and its constructive rest, catia isnāt much used in solid mode.
Well you can argue if this is good or not, but the common argument is, that solid and so 100% parametric modelling has its limits when it comes to explicit shape control. And even for constructive parts, its not uncommon that a catia guy asks a direct modelling expert for assistance.
I know Solidworks from my student days, and its a very good program. I also believe there was made a huge evolution in modelling capabilities, so many things can be done from a solid modeller only nowadays. I also believe that for 99% of all modelling tasks you can stay with solidworks and it will give excellent results. So yeah, borders begin to disappear, but tools of high-end surface modellers are still unmatched and so there is always a good reason to loose parametric and solid description and to tweak controlpoints manually.
Well, the question was can one do with solid modelling software what one can do with Rhino, and I would say SolidWorks is an excellent choice, looking how fast it spreads in top-tier and second-tier design studios. Maybe it is different in the U.S.
Of course, in high-end automotive or product design, youāll see Alias or ICEM for exterior surface definition.
The recent Dynamo update and demonstrations where very impressive, meshing with existing Autodesk softwares.
Like I said, it depends on industry sector and business segment.
100 % agree.
Iāve been to an Autodesk event 2 month ago. Iām still disappointed regarding Dynamo. Donāt know the latest release yet, but when I used it with Alias it was impossible to create geometry usable for real application. Grasshopper/Rhinocommon is much more advanced.
What in my opinion will become a gamechanger if the Alias tools will be callable from script (OpenAPI). This is planned, but its rather a mid term goal.
For product design, I found the current iteration of Autodesk Dynamo a game changer, as far as what is needed in this sector is concerned. For automotive, it might be a very different story, as that is a highly specialised industry.
In your opinion, what does Dynamo better compared to Grasshopper, regarding product design? What is the game changer?
Itās not about ābetterā. I find it, considering use in industrial design studios, more intuitive and less cluttered, less specialised. In industrial design, you often canāt allow fiddling around with an overload of options, as interesting as that is. Also, from a commercial standpoint, I find the integration of Dynamo, Alias and Speedform very compelling, in terms of managing users, the studio software base, etc.
Thatās a good point. Its definitely a big plus if everything is within one base and if its more intuitive (although this is subjective). Furthermore Iām working with GH for 7 years now, so Iām maybe biased and high on expectation
For me Dynamo is not bad at all, but nothing special (yet).
Its just another visual programming editor. Grasshopper wasnāt the first one either.
There is just one aspect, which disappoint me a bit:
It is incredible hard to maintain clean geometry (not class A in particular, but just simplified geometry).
In my understanding this is due to the fact, that its not the Alias geometrical kernel, which is used. I give you an example; I was testing Dynamo by doing a simple perforation pattern. The problem, the moment you project circles each circle contains hundreds of cp. This not only slows everything down, it also makes it impossible to build from it further. Sure if you use Grasshopper, you have similar limitation based from Rhinocommon. However, since Rhinocommon is a rich toolset you can simply build workarounds. This isnāt intuitive and needs a lot of expertise yes, but at least its possible. Imagine being able to use what Alias gives you. This immediately will change everything (at least for me), and if you believe what AD says this will come true one day. So Iām still high on expectation
Itās indeed not, itās the ProtoGeometry kernel. Which in turn was/is the geometry kernel from DesignScript, which in turn is partially what Dynamo is built upon (the node-in-code scripting language itself is DesignScript). And it is in my experience also indeed no RhinoCommon.Geometry! While I certainly wouldnāt dissuade anyone from picking up Dynamo (especially if youāre using it within Revit for Revity things i.e. not using ProtoGeometry etc.), but in comparison to using Grasshopper/RhinoCommon it really is a pain* on almost every single comparable level.
*Speaking from admittedly limited Dynamo experience, but enough to form a somewhat qualified opinion.
Yes, many studios are looking at the Speedform/Alias conjunction again, with so many new functions, complementing the SolidWorks/Creo workflow. Exciting times for industrial design.
