V5
here is a cropped sample from top left to show text progression,
see attached for the full version,…(now attached tif as zip as the jpg was fuzzy) (4.7Mb) its a grid with a text array, I need to recreate this without the anti aliasing of the text, so text is pure black pixels.
the grid is easy array work, or is it, would I use line and a thickness, and what thickness for a 1pixel result ?
…but can the text be made., its probably something that excel can do but I need control over its size hence Rhino.
size has to be same pixel dimensions as this,
Then get it out and into photoshop so again how ?
export as pdf I presume.
If anyone can do this and post result as well as explain I would be very grateful.
Cheers
Steve
Text grid array-1.zip (517.2 KB)
