Can objects given pipe command rad start and end 1.5 be altered en masse to 0.75 rad?
V5,
is there a quick way to alter objects I have already given radius 1.5mm to, to be half that radius ?
(History was not turned on)
They are straight ‘wires’., forming a grid.
Cheers
Steve
If the wire are blocks, you can sketch wire with new radius and use command “replaceblock”
Unfortunately they were not blocks, as I had no expectation to alter them.
Steve
If the objects are uniformly distributed you can use command recangular array.
array is probably quickest then.
if not then either redo them all or use scale 2D on ends of straight wires, one at a time.
Is there a way of applying scale2d to items requiring same scale factor at their ends but not evenly arrayed ?
Cheers
Steve
