I am running Rhino 6 SR16 for Windows.
I am not incredibly experienced with Rhino, so I most likely missing something very obvious.
I cannot seem to get the Flow Along Surface command to behave in the way I would like. I have created a domed cylinder by making a circle, extruding the curve to a specific distance, and then creating the specific angle I want.
I then used the Revolve command to turn that domed curve into the desired shape. I joined everything together, and it was a valid solid. However, any time I attempt to use Flow Along Surface to lay a solid on top of it, the solid ends up distorted.
I suspect it is due to the rotate command and its directional nature, so I tried a few other commands to achieve the same effect (such as Sweep1) and the problem is the exact same. The object is laid out correctly if I use the “Patch” command, however opens up a whole other bag of badgers and the edges do not match up correctly.
What could I do to fix this?
