I’m not able to finish the command I the way I want when I copy hole in surface. Enter would not complete the command.
It works fine when I do not press UseLastDistance, but I would really like to have that option and all other options on “Yes” so I quickly can do multiple copy’s
Yes, I see this, in fact this looks to be completely buggy in V7, the command goes into an endless loop, only way to finish is to hit Esc. Same in the current WIP…
@rajaa ?
Hi -
Thanks for reporting this issue.
I’ve put it on the list as RH-76911 CopyHole: UseLastDistance prevents command from finishing
RH-76911 is fixed in Rhino 7 Service Release 34 Release Candidate
