I was told by an acquaintance that Rhino 6 give problem when used offline. I wanted to know if it was a problem in itself or not
Hi - Yes, you can use Rhino 6 offline. If you will never connect to the internet, you will have to install Rhino as a stand-alone version. If you can connect to the internet once in a while, you can have your license in the Cloud Zoo.
Hi @wim, is there anything a user can do to enable F1 help when offline ? Will there be a chm helpfile instead of the online help ?
_
c.
