i am modeling an object in grasshopper that will be a component of an assembly and am trying to get vertices or edges from the main subd object into grasshopper so it will always join at thesese points even if the subd objects scale or position changes.
I tried using pt geometry node but it doesn’t let me select vertices. Then i tried SubDVerts but this only gives me the control points not the vertices.
