…my default rendering output these days is just a screen-grab of the current Neon viewport. Is there any way to specify the size? Apart from dragging the edges which never gets an accurate result…
Type
-ViewportProperties
in command line and you will see size option…
Yes, make a floating viewport by dragging on the viewport name up to the command line and releasing it or use the command NewFloatingViewport. Then in the Properties panel, you can edit the width and height for that viewport when nothing is selected.
Brian and Chris, thank you both
