Can i send commands to rhino from another application (link to excel sheet)?
I was thinking of a script that zooms to a certain location in the rhino doc when i click a button in an excel spreadsheet… is this possible to do with VBA?
Yes you can use send keys and Rhinos vbscript or python etc. syntax in excel using vba and bind it to a cell or button. You will need to use zoom and an xyz location or worse mouse cursor location might be harder to code or select an object and zoom selected might be the easiest way.
RM
You can use CreatObject,like this:
Sub test()
Set rhino = CreateObject(“Rhino.interface”)
Set rs = rhino.GetScriptObject()
Call rs.Command("_Circle 0 100")
End Sub
