Im doing a project of a sound reactive device with Firefly, Kangaroo and Arduino. My idea was to use a servo to act as the moving points(the points after the kangaroo physics).
Is there and clue that I can get the length and the coordinates of the moving points? so I can calculate the spinning of the servo.
You can get the x,y,z coordinates of any point in Grasshopper using Deconstruct Point, found in the Vector>Point tab.
From your definition I guess you’d want the points from ParticlesOut.
(You might want to look at remaking this definition using the current version of Kangaroo)
