Can I fillet edges of a mesh?
No, there is no “mesh fillet” tool in Rhino…
Uh, thanks.
You can do meshtonurbs ,not sure if I spelled it correctly…, then fillet the nurbs, but…
not sure if you want to fillet mesh edges or if you can get desired results…
Hi @einstein
If it’s fairly small radii and for visualization only, you can use applyedgesoftening on the mesh.
HTH, Jakob
Ok, thanks for you responses.
Think I’m just hitting the wall by expecting that I can work on meshes in Rhino like in 3dsmax.
