Can I change the parameters of Swept Blend Generic Model In Grasshopper
Hi there,
I created swept blend generic model in revit rfa file and there, I determined the parameters like length, width, etc as I desire to be connected and changed with grasshopper script. After I loaded this family data into the project, and at the time, I connected the scripts like this in the picture, but I cannot find all the dimension parameters, like width under Inspect Element parameter. How can I solve this problem? If you all have any solutions, please explain it to me.
Thanks.
The Instance of the Element has a different set of Parameters than the type. You’ll want Inspect the Type.
Thanks for your kindness, Mr Japhy
The problem has solved because of your reply. Have a good day!
