Can I change the folder path of texture file of .skp file?
When I import .skp file, the texture file will save as the temp folder. Can I change a fixed path on Rhino 5,6,7 ?
Anyone know that?
can you share the settings you are importing with? or a specific file? I’m not well versed with skp import, but I know that Rhino Saves embedded files in a folder next to the .3dm file
When I import the skp files, the texture file of skp drawing file to the windows temp folder. Can I set the another folder to save the texture file of skp drawing, thank you
Try unchecking these 2 Items, Rhino will extract the textures to the folder next to the skp file where saved.
Thank you very much ! :pray: :pray:
I check these 2 item usually :smiling_face_with_tear:
you’re welcome, make sure to make this thread to be solved , this can help others having the same question.
