mir_on
February 7, 2015, 9:41pm
#1
Continuing the discussion from TSplines 4 for Rhino released :
This just in… FYI…
Version 4 of Autodesk T-Splines Plug-in for Rhino has been released. This version is highlighted
by T-Splines Grasshopper integration, modeling improvements, and better
integration with Rhino 5.
If you are an existing T-Splines customer, for a limited time you
can get 70% off T-Splines v4 through a reseller or by using coupon code TSPLINE at
the Autodesk store. Network licenses of T-Splines are now available
(exclusively through resellers), as are free student licenses.
If you bought T-Splines after 3 July 2013,
you can purchase an upgrade through your Autodesk account or through your
reseller. If you bought T-Splines before 3 July 2013,
you can buy T-Splines v4 at a 70% discount (essentially the same price as
an upgrade) at the Autodesk Store (use coupon
code TSPLINE) or through your
authorized reseller. This discount is available until July 15, 2015. If you live in Japan or Korea,
this discount is only available through your authorized reseller.
< other Autodesk stuff snipped >
Sincerely,
The T-Splines team at
Autodesk
I bought T-Splines 3.5 after 3 july 2013. I dawnloaded trial TS v4. If I try activate it with using my serial number from v 3.5, with differen produkt key (A46F1 and A46G1), It’s inform me that my serial number is not valid. Should I have new serial number? How to get it?
bobmcneel
(Bob McNeel)
February 13, 2015, 6:14pm
#2
I’m not sure anyone here can help. Perhaps you need to contact the T-Splines crew directly.
