As you see this is a medical image. I want to isolate all the bright points surrounding the black area (some bright points are indicated by red marker), then get the location of these bright points (pixel number). I know many people realize the similar work in Matlab. Here I wonder if GH can have a possibility to do the work.
get the avairy plugin you can use this to deconstruct the bitmap.
you will need to assign a point to each pixel to get each color value. this will mean an initial compute time that is very heavy. however once you have this information in a list it will be easy to analyse it. steps will be:
Avairy plugin:
Read bitmap
Sample bitmap or native gh. image sampler
Deconstuct colors into hsl
analyse dark and light portions of image.
5 you could also analyse other parts of the image for color values, reds, greens, blues, or hues etc.
optional - to visualise the colors you will need to spray a mesh face with each color, you can then do a cull to see the affected pixels - an image of 1000x1000 will be heavy, but it will be work it…
Thank you so much, arkadius, for your valuable suggestions!
I never use this plug-in and I need some time to get familiar with it. I am sure I will meet problems and questions and I really wish you are still helping me!
Thanks again,
