I have drawn a curve and need to make it precisely 4191mm in length, is there an easy way of doing this?
Many thanks in advance,
Si.
Si.
If you want to trim the curve to a specified length use SubCrv
If you want to change the length scaling the curve then use Scale with a scale factor equal to desired length / current length. Current length can be found using the Length command. The scale factor can be entered as a fraction; for instance as 4191/5034.6 if the current length of the curve is 5034.6.
Thanks David,
Got it!
