Rhino documentation says: “The ApplyMesh command fits a mesh onto a surface. The applied mesh must have the same number of mesh vertices as the source surface mesh.”
What is the difference between the applied mesh and the source surface mesh?
Hello - actually, as far as I can see in V6, this command does not work at all. See V5 for an actual working version to see how it is supposed to work… Thanks for the report.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44368
“You have no permissions to view this page”
