I am creating a set of toolbar buttons with python scripts under the buttons. Two of the buttons import a 3dm and one adds a layout file to the import. There is also a display mode I need to add. Currently I am doing this before the ! _-RunPythonScript ( header. Done this way requires the full path to the files to be present under the button.
This toolbar will be distributed out to the enterprise across a very diverse network so it would be great if I did not need to change file paths on each users toolbar to accommodate the diverse network / language issues. It would seem that if I create a .rhi file that puts everything in the local users plugins folder I can use a global file path statement in the python to import those .3dm files.
If this is possible, what does that look like?
