Can a crashdump file be repaired?
I have a file that crashed. Opened it and renamed it , put it in a folder. It still crashes when I do a certain operation. I can send it in to have you look at it. Just wondering if crashes are repairable? Thanks,Mark
The bug that is causing them hopefully is. So if you have specific geometry and a workflow that repeatably makes Rhino crash, then you should send that file and workflow to McNeel.
It might be possible to change the geometry by using other commands so that Rhino won’t crash further down the line but there is no baked-in function that will do that - if that’s what you had in mind. Are there any objects in the file that Rhino flagges as bad?
Wim, I didn’t look into the bad objects , but when I’m need the internet I’ll send it in with explanation . —Mark
