Hi everyone!
I am new at using the camera, and the reason I want to use it is to shorten topography from a specific viewpoint that I might be seeing a mountain from. So I want to use the camera to orient the gumball to, and then scale the topography in that direction. I am not sure if that makes sense so I will attach a file. I want to see this view:
changing the focal length of the camera in perspective view to see the changes is not an option? also not sure if i understand what you want but it seems you squashed the landscape instead. setting the camera to something like 80 mm or more shortens the landscape optically if thats what you want. and you can stay on the same position.
