Hi there,
I am required to do landscape perspective renders; and a consistent problem arises.
In the image above, my focus point is the top of the flagpole. Look at the bottom of the screen, the ground is cut.
WHen I turn on the camera, you can see that it’s a massive thing, and intersects with the ground plane; as my focus point is relatively far away.
I can manually pull it back from this side view to make the camera smaller for still renders (not raytracing with aperture depth), but this is very inconvenient.
Ideally, I want my camera not to increase in size based on my focus distance. I want to be able to focus very far in the distance, at any focal length, and the camera stays the same size. This is absolutely vital for the ‘turntable’ command, where i must focus on the flagpole.
Best,
Jeremy
