Calculated planar surface not planar - rounding problem or me?
Hello everyone,
I am trying to construct a brilliant cut with c# in grasshopper with all the important attributes given from diamond reports.
the kite facettes seem to be a problem though:
here a plan how I planned to get the kite facets (turquise polyline) planar:
the red lines are given (r of rc and all offsets in z and y direction.)
22.5° are given by the 1/16 division by the brilliant cut, and therefor 67.5° the relevant angle.
then the blue circle, resp. its radius is calculated by radius= fc.radius/math.sin(67.5°).
This seems not very complicated to me, but in the result the facet is never drawn, as its not REALLY planar and therefor returns null:
Now am I missing some basic math skills or is it the good old rounding problem of double values having x.000000000000000344 fragments on it? How would I get around this?
brilliantCut_0.gh (11.5 KB)
and here the relevant pieces of code:
    //settings defs
    int div = 16;
    double alpha = 360 / div;
    double beta = 90 - alpha;
    double cfRatio = 0.5;
    //input checks
    if(Pl == null) Pl = new Plane(Plane.WorldXY);
    if(crownRatio == 0.0) crownRatio = 0.180;
    if(girdleRatio == 0.0)girdleRatio = 0.022;
    if(pavillionRatio == 0.0)pavillionRatio = 0.380;
    if(tableRatio == 0.0)tableRatio = 0.600;
    //geo defs
    Vector3d plNorm = Pl.ZAxis;
    plNorm.Unitize();
    //diameter to use
    BoundingBox bbox = C.GetBoundingBox(true);
    Point3d[] corners = bbox.GetCorners();
    //double avgDiam = Math.Round((corners[0].DistanceTo(corners[1]) + corners[0].DistanceTo(corners[3])) / 2, 2);
    double avgDiam = C.GetLength() / Math.PI;
    //curve.table
    var tcX = Transform.Translation(plNorm * avgDiam * (girdleRatio + crownRatio));
    Curve tC = offsetInside(C, Pl, avgDiam / 2 * (1 - tableRatio));
    tC.Transform(tcX);
    //curve.crownfacette
    double midRadius = ((avgDiam * (1 - tableRatio) / 4) + (avgDiam / 2 * tableRatio));
    double cfRadius = midRadius / Math.Sin(RhinoMath.ToRadians(beta));
    var cfcX = Transform.Translation(plNorm * avgDiam * (girdleRatio + (crownRatio * cfRatio)));
    Curve cfC = offsetInside(C, Pl, avgDiam / 2 - cfRadius);
    cfC.Transform(cfcX);
    //curve.rondist
    var rcX = Transform.Translation(plNorm * avgDiam * girdleRatio);
    Curve rC = C.DuplicateCurve();
    rC.Transform(rcX);
    //points.oncurves
    //points.table
    List<Point3d> tcP = new List<Point3d>(filterList(divideCurve(tC, div), true));
    //points.crownfacette
    List<Point3d> cfcP = new List<Point3d>(filterList(divideCurve(cfC, div), false));
    //points.rondiste
    List<Point3d> rcP = new List<Point3d>(divideCurve(rC, div));
    //breps
    List<Brep> breps = new List<Brep>();
    //breps.kitefacette
    for(int i = 0; i < cfcP.Count - 1;i++)
      List<Point3d> kite = new List<Point3d>();
      kite.Add(cfcP[i]);
      kite.Add(tcP[i + 1]);
      kite.Add(cfcP[i + 1]);
      kite.Add(rcP[i * 2 + 2]);
      kite.Add(kite[0]);
      Curve plln = new Polyline(kite).ToNurbsCurve();
      bool tst = plln.IsPlanar();
      Rhino.RhinoApp.WriteLine(tst.ToString());
      Brep[] tmpbrep = Brep.CreatePlanarBreps(new Polyline(kite).ToNurbsCurve(), 0.001);
      if(tmpbrep != null) breps.AddRange(tmpbrep);
    G = breps;
  // <Custom additional code>
  public List<Point3d> divideCurve(Curve C, int n)
    List<Point3d> lOut = new List<Point3d>();
    double[] divT = C.DivideByCount(16, true);
    List<double> tL = new List<double>(divT);
    foreach(double t in tL)
      lOut.Add(C.PointAt(t));
    lOut.Add(lOut[0]);
    return lOut;
  public List<Point3d> filterList(List<Point3d> input, bool pair)
    int start = pair ? 0 : 1;
    for(int i = start;i < input.Count;i = i + 2)
      lOut.Add(input[i]);
    return lOut;
  public Curve offsetInside(Curve C, Plane Pl, double dist)
    Curve[] c0 = C.Offset(Pl, dist, 0.001, CurveOffsetCornerStyle.Round);
    Curve[] c1 = C.Offset(Pl, -dist, 0.001, CurveOffsetCornerStyle.Round);
    Curve oC = c0[0].GetLength() < c1[0].GetLength() && c0[0].IsClosed ? c0[0] : c1[0];
    return oC;
thank you in advance
Ben
EDIT: the constructed length (which works) is 4.330 for the blue radius, while the calculated is at 4.3295688.
I had
instead of
double alpha = 360.0 / div;
what a stupid error…
