As you see here I want to tweak the Texture to match the other patterns. Is there a way to set any low poly mesh or polyline as a control polygon?
Hi Hannes - have you tried working with the UVEditor?
@pascal Unfortunately I can’t see the texture when switching on UVEditor. It turns invisible. Any ideas how to switch it on would be very handy. Many thanks! Hannes
Hi Hannes - move/adjust the mesh points in the projected/unwrapped texture mesh not the actual mesh object… I’m not sure if I am interpreting correctly what you are showing there.
@pascal will do so until I figured out why the material and mapping don’t show up anymore. Posted as a new topic
Pascal made it working, but as I’ve said there is no texture to see the results in real time. As I don’t know how to edit the texture.
Hi Hannes - can you send me what you’re working with?
thanks,
Sure. do you need any textures?
UVEditor Issue.3dm (835.9 KB)
