I’ve recently started using rhino with mac and it works really good. I’m using MBP M3 Max 2023. I’ve just bumped in to issues when using the CageEdit function, Rhino crashes almost every time when I try to adjust the cage. Could this be a bug in the mac version or is it something with my file?
Gijs
(Gijs de Zwart)
August 16, 2024, 9:40am
2
hi @Agnes_Vannerus
pls run _SystemInfo in Rhino and post back the results. If you have a model that illustrates the crash, it would be very helpful to send us that file.
Hi @Gijs
Here are the results:
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13002, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
License details: Cloud Zoo
Apple macOS Version 14.3 (Build 23D56) (Physical RAM: 36GB)
Mac Model Identifier: Mac15,11
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M3 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
Generic: Flash Card Reader/Writer
Logitech: USB Receiver
VLI Inc.: USB 2.0 BILLBOARD
VIA Labs, Inc. : USB Billboard Device
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Users/felixwindolf/Library/Application Support/McNeel/Rhinoceros/8.0/MacPlugIns/Enscape.Rhino8.Plugin.rhp “Enscape.Rhino8.Plugin” 4.1.0.2288
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.8.24170.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.8.24170.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.8.24170.13002
Gijs
(Gijs de Zwart)
August 16, 2024, 9:54am
4
@Agnes_Vannerus can you send the model that crashes with cageEdit? If too large and/or confidential, you can upload it here .
test.3dm (129.3 KB)
@Gijs when I select the upper right control points and try to pull them down two times (with the gumball) in a row the program crashes every time.
Thanks for the help
Gijs
(Gijs de Zwart)
August 16, 2024, 12:09pm
6
@Agnes_Vannerus do you get a crash dialog when this happens? If so, it will be helpful to send these in. The crash reports are an important instrument to fix crashes and make Rhino more stable.
So far I was unable to make mine crash.
One thing to try is to disable Enscape and see if Rhino still crashes.
No dialoge box appears unfortunately. Not sure how to disable enscape without uninstalling it?
Gijs
(Gijs de Zwart)
August 16, 2024, 1:37pm
8
to disable a plugin, go to Options > Plugins and uncheck the plugin you want to load at startup. Then restart Rhino
the issue remains even when i’ve disabled enscape
Gijs
(Gijs de Zwart)
August 16, 2024, 1:53pm
10
@Agnes_Vannerus sorry, I should have looked right away in youtrack:
RH-82821 Cage: CageEdit crashes in Rhino 8
So updating your Rhino to the latest SR should fix the issue you are seeing.
