yes but in this case there are 2 different degrees, one direction can only be degree 1 while the other is degree 2 or 3… and one has to know that first or find out trying after counting the points. which involves some brain jogging. so not that direct i would say.
after a few times trying i still failed, now i tried again and managed because i used degree 3 instead of 2. i had given up before, because after 30 minutes clicking around, the surface i finally managed to produce once not twisted or tangled up did not close up properly. so thanks for the work out
