Cage Edit or Equivalent to add creases and facets?
I realize that I could just edit the points and insert a new edge to deform the object as desired in the illustration below, which I’ve keep simple for illustration purposes. I’d like to accomplish this on objects with much more numerous faces
If this is a subd, you can use SubD Knife to add edges where ever you want. you can then use gumball to edit it as needed.
Thanks Kyle. But in the case of an object like the below, there are too many faces to individually use the gumball on. So I’m looking for a something that will edit each of these objects (there are many of these, all different)) more globally with far fewer points.
you can set the cage to degree 1
this is what i also thought on first seeing this topic - but as soon as the cage orientation and the U-V s of the surface do not match you get a crazy dense surface - still not a sharp / real crease or edge:
maybe the simple answer is:
no there isn’t.
use standard, manual solid,nurbs / subD / mesh edit tools to do so.
actually in my most recent example the new positions of the upper points can hinge on the existing horizontalish edges. But in the example below, it would be really handy if the cage edit (or equivalent) added a crease along the length of the many vertical edges. Otherwise there’s a lot of editing of individual faces, and there could be sixty of these differerent shards each needing to be frequently adjusted.
By the way, I couldn’t find a command “subdknife.” Maybe it’s only in R8, which I’ve just upgraded
Knife is v9 only.
-Jakob
using a bounding box set to deg 1 with a number of points you require may help
