Cage BoundingBox CPlane Bug
Cage is broken when using custom CPlanes.
Macro:
Cage B pause C Enter
File:
CageBug.3dm (191.1 KB)
Workaround:
Use a bounding box:
BoundingBox Pause CoordinateSystem=CPlane Output=Curves Enter
Then in Cage/CageEdit, select BoundingBox 3Point and use the curves as your base points.
Hello- thanks, I see that. CageEdit seems to get it right though.
RH-62334 Cage: CPlane aligned bounding box is incorrect
Huh, I assumed CageEdit used Cage, but that’s a far better workaround.
