Cache component doubt
Hello everyone,
I am currently using the new Cache component in R8 for the first time. I have noticed that when I open grasshopper, the component cache does not function properly. It appears to be waiting for the canvas to be updated. However, if I recompute the canvas, then it starts working. Is there a way to make it work automatically when opening the GH file, without needing to recompute?
Thanks in advance!
Hi B. Balbvastre,
You can use a Value list to populate the input variables.
If a command is in the middle of running in Rhino you will get that error.
Hi @Japhy
Thanks you for the answer and for the suggestion! I was just trying to create a simple example
Then, is there a way of delaying the cache component in order to wait for rhino canvas to be created? I am sharing the scripts with other non GH users and that can be a problem since if you open the script, it does not work until you recompute it
Hi @bbalbastre,
This will be solved on next 8.13 RC.
Thank you for taking action on that :slight_smile:
