I’m using Revit 2026.4 together with Rhino 8.29.
When extracting Cable Tray geometry from Revit into Rhino using the Element Geometry component in Rhino.Inside.Revit, the resulting geometry is always a simple BOX (bounding box), regardless of whether the Detail Level is set to Fine / Medium / Coarse. The output does not reflect the actual tray profile.
Is this the expected behavior for Cable Trays in Revit
Is Rhino.Inside.Revit able to access the true Cable Tray geometry
