C# What is a correct way to remove several ngons from mesh that has ngons?
I would like to merge several connected ngons into one.
Before doing that, I expected I could remove several existing ngons ones, and then create new ones.
But when I print how many ngons are before and after removal I get the same number.
What would be an approach to my problem?
        Rhino.RhinoApp.WriteLine(mesh.Ngons.Count.ToString()); //Prints 55
        mesh.Ngons.RemoveAt(1);
@Petras_Vestartas, have you tried to apply the changes to the object in the Rhino document using:
rh_obj.CommitChanges() ?
_
c.
Hi Clement,
The issue is that geometry is not baked in rhino but created in .net.
Nevertheless, I solved my issue without removing ngons.
