C# - select objects by Layer
Firstly, I am still a beginner in C# and still trying to understand how it works.
So, what I am trying to do is to make a script that automatically selects all objects in a specific layer.
private void RunScript(int inLayer, ref object A, ref object B)
//select specific layer in rhino doc
Rhino.RhinoDoc doc = Rhino.RhinoDoc.ActiveDoc;
var selLayer = doc.Layers.FindIndex(inLayer);
//get objects in layer
Rhino.DocObjects.RhinoObject[] objs = doc.Objects.FindByLayer(selLayer);
A = selLayer;
B = objs;
However, instead of selecting the objects, it just selects the object’s properties ( I guess).
MeshObject: (unnamed) (2065376000)
ExtrusionObject: (unnamed) (0)
Can someone explain to me why does this happen? and how to solve this?
Thanks!
You must select objects after finding them:
private void RunScript(string layername)
    Rhino.DocObjects.RhinoObject[] rhobjs = doc.Objects.FindByLayer(layername);
    for (int i = 0; i < rhobjs.Length; i++)
      rhobjs[i].Select(true);
Zaqi.gh (12.9 KB)
Hi Mahdiyar,
Thanks for your help! But it still shows these in the output:
BrepObject: (unnamed) (0)
MeshObject: (unnamed) (-2102460576)
Would it be possible to reference the geometry instead of the properties in the output?
Thanks,
Z
Sorry for misunderstanding, I thought you want to select them in Rhino Viewport.
    List<object> ghobjs = new List<object>();
    foreach (Rhino.DocObjects.RhinoObject rhObj in rhobjs)
      ghobjs.Add(rhObj.Geometry);
    A = ghobjs;
Zaqi.gh (12.2 KB)
ahh, great!! super!
Thank you so much for your help!
Best,
Zaqi
Is the a way to select object in sub-layers of that layer too?
var ghobjs = new List<object>();
var selectedLayer = RhinoDoc.ActiveDoc.Layers.FindName(layerName);
var layers = new List<Rhino.DocObjects.Layer>(){selectedLayer};
if(subLayer)
  foreach(var layer in RhinoDoc.ActiveDoc.Layers)
    if(layer.IsChildOf(selectedLayer))
      layers.Add(layer);
B = layers;
foreach(var layer in layers)
  var rhobjs = doc.Objects.FindByLayer(layer);
  foreach (var rhObj in rhobjs)
A = ghobjs;
Adnanmakda95.gh (16.1 KB)
Thank you for such a quick response. Works perfectly well. Thank you once again!
I wanted to import a .3dm file with all layers and textures grasshopper. Do you think its possible?
I’m not sure if I understand what you mean by importing. Maybe read3dmFile component from Human plugin could help.
