C# sample broken in Simple Parameters (C#)
Rhino Version 7 SR15
(7.15.22039.13001, 2022-02-08)
GH version:
protected override Kernel.GH_GetterResult Prompt_Singular(ref TriStateType value)
  Rhino.Input.Custom.GetOption() go = New Rhino.Input.Custom.GetOption();
  go.SetCommandPrompt("TriState value");
  go.AcceptNothing(true);
  go.AddOption("True");
  go.AddOption("False");
  go.AddOption("Unknown");
  switch (go.Get())
    case Rhino.Input.GetResult.Option:
      if (go.Option().EnglishName == "True") { value = new TriStateType(1); }
      if (go.Option().EnglishName == "False") { value = new TriStateType(0); }
      if (go.Option().EnglishName == "Unknown") { value = new TriStateType(-1); }
      return GH_GetterResult.success;
    case Rhino.Input.GetResult.Nothing:
      return GH_GetterResult.accept;
    default:
      return GH_GetterResult.cancel;
protected overrides Kernel.GH_GetterResult Prompt_Plural(ref List<TriStateType> values)
  values = new List<TriStateType>
  while (true)
    TriStateType val = null;
    switch (Prompt_Singular(val))
      case GH_GetterResult.success:
        values.Add(val);
        break;
      case GH_GetterResult.accept:
      case GH_GetterResult.cancel:
        values = null;
To my understanding, the correct syntax should be:
  var go = Rhino.Input.Custom.GetOption();
  switch (go.Get())
    default:
  values = new List<TriStateType>;
  while (true)
        values.Add(val);
        break;
        values = null;
Am I understanding it correctly?
Whoever did this into GH SDK was definitely not a responsible contributor… simply look at the misaligning indents 2 vs 3:
If it is a pseudo code, call it a pseudo code but don’t say sample. It would mislead others.
Same problem in the online version of the Grasshopper SDK:
https://developer.rhino3d.com/api/grasshopper/html/fbfe5e40-ba8d-4e53-97c6-27572e049835.htm
