I am trying to add “RhinoScript” to references but getting this message! Rhino Script|689x393
If I’m not mistaken you should use tlbimp.exe to convert it to a .net assembly, then reference that assembly. See https://www.oreilly.com/library/view/c-in-a/0596001819/re18.html or google for tlbimp.exe
Hi @karakus.bulent,
I had no problem referencing the RhinoScript 7 Type Library in a .NET Framework console application using VS2019. Can can you tell us about the project you are trying to add the reference into?
– Dale
I am using VS2019 as well, the project that I am trying to add “RhinoScript 7 Type Library” is a class library, the target framework is 4.8
Hi @karakus.bulent,
I was also able to add reference to the RhinoScript type library in a .NET Framework class library project.
Sorry, I’m not sure what is causing this.
– Dale
