C# Rhino Compute - Could not load file or assembly 'RhinoCommon
Hi Everyone, I’m new with rhino compute and I having trouble, hope you can help with this problem. I’m trying to execute this code from this post Grasshopper within compute.rhino3d - #34 by will
But I have one problem, once it reaches this in rhino Compute “JsonConvert.SerializeObject(obj, GeometryResolver.Settings);” it gives an error with compute that said:
“System.IO.FileNotFoundException: ‘Could not load file or assembly ‘RhinoCommon, Version=7.19.22180.9001, Culture=neutral, PublicKeyToken=552281e97c755530’ or one of its dependencies. The system cannot find the file specified.’”
I already have installed the dependency RhinoCommon with nugget in that version but not sure what it’s given me that error, I let the code that I try to execute below once it try to create new GrasshopperPath(0) it’s go to rhino compute when it generate the problem, I let an attachment of that
Thanks in advance!
 class Program
        static void Main(string[] args)
            var ghPath = "C:\\Users\\ivan\\source\\repos\\Resthopper\\squared.gh"; //args[0];
            GrasshopperDataTree gdt = new GrasshopperDataTree("RH_IN:1");
            gdt.Append(new GrasshopperObject(3.0), new GrasshopperPath(0));
            var inputs = new List<GrasshopperDataTree>() { gdt };
            var result = GrasshopperCompute.EvaluateDefinition(ghPath, inputs);
            foreach (var item in result)
                Console.WriteLine(item.ParamName);
                foreach (var path in item.InnerTree.Keys)
                    Console.WriteLine("{0} => [ {1} ]", path, string.Join(", ", item.InnerTree[path].Select(x => x.Data)));
@Ivan_Astrada, do you know the answer/solution to this problem now?
