problem occures:
Rhino 6 64-bit and SafeMode
Rhino 5 64-bit
problem doesn’t occur:
Rhino 5 32-bit version and SafeMode
I reinstalled all .NET frameworks since the alink.dll is a part of it without any success. Even reinstalling or repairing Rhino 5 and Rhino 6 didn’t help!!!
How to find the location of the alink.dll c# is using?
During the repair process of Rhino 6 the .NET 4.5 is repaired. Since GH is now a part of Rhino 6 the alink.dll should be replaced/repaired in case of damages or wrong -bit versions?
Is Rhino 6 using a new .NET version which I have installed and the repair of the damaged alink.dll in .NET 4.5 has no impact?
I don’t know what alink.dll is for, or who is responsible for making/distributing it.
Seems like it might be part of the compiler/linker, but that’s just based on a single comment I found online. @stevebaer@brian, do either of you know whether this dll could be affected by us installing a .NET framework? Do we even still do that in our own installer?
beside your four registration I have four more registration in .net 2.0 and .net 4.0 both in 32-bit & 64-bit versions. Having Rhino 5 and Rhino 6 installed:
empty C# componants do not return this problem. Even a simple A = x; causes the missing alink.dll problem on my computer … All not working C# componants work fine on other machines
@kaspar-ehrhardt on the machine it fails do you have Visual Studio installed? If you do you probably need to repair the installation. IIRC alink.dll is loaded with VS.
