Hi all,
I am trying to reset the Cplane and am having no luck using any and all combinations.
Learning about how c planes truly work I can see that a 90 ° degree is the standard and that cannot be changed.
But I am struggling failing a way to be able to move my geometry in a straight perpendicular fashion to the top half of my model which must remain at the standard 90° degree orientation.
The top half of my model must maintain its location at 90° but the bottom “legs” half needs to be at 135° and I need to be able to move the bottom half’s elements at that angle. I hope that makes sense.
Normally when facing a problem like this I would rotate the top half to suit but this won’t work? Any ideas, is this trick even possible in rhino?
