C# - offset inwards, null exception
Hi! I am struggling to figure out null situation when I use Curve.Offset Method.
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_Offset.htm
The intention of this script is to make multiple offset curves (inwards) with certain distance.
The script works when I reduce the offset distance in half. Thus I assume that there is a way to estimate maximum range of offset distance to avoid failure/null situation.
can you give me some advice how to make this script work?OffsetInwardsNull.gh (12.9 KB) :sweat_smile:
Thanks for your comments!
Moved to Rhino Developer category so it will be seen.
Just check for null in your script then and exit the loop. Or are you looking for a way to know beforehand how many offsets you can produce?
yes! is there any way to know possible (inward-offset) range?
I think this should do what you want?
OffsetInwards_null_check.gh (20.3 KB)
depends highly on the input if a offset fails. You can make an estimation but I think it is just as fast to make the offsets and count them
