Hi:
I want to load some file in the plug-in path, but I am new in c++, how cant ia get the current plug-in path?
You can get the full path to your plug-in by calling your plug-in object’s GetPlugInFileName member.
– Dale
Thinks @dale I am try it now.
Hi @dale :
Cant you give me some sample?
I try it but I do not kown how to usd it
The CRhinoPlugIn::GetPlugInFileName()
function is a member function, not a static function. Thus, in order to call this member function, you will need to have your one-and-only plug-in object.
For example:
BOOL CTestPlugIn::OnLoadPlugIn()
ON_wString filename;
if (GetPlugInFileName(filename))
// TODO...
return CRhinoUtilityPlugIn::OnLoadPlugIn();
Hi @dale:
It run good , thinks.
