Hello
I’ve been using the Make2D
component in Grasshopper to create some automated assembly drawings, but looking to move it into a Rhino Plugin using HiddenLineDrawing.Compute
I have a multiple components in an assembly, and when using Make2D
in GH I collapse these components down into a single branch per assembly, i.e.
{0}[comp_A, comp_B, ... comp_X], {1}[comp_C, comp_D, ...]
I do this so Make2D
can compute the occluded view/hidden line drawing as different components can overlap sometimes. Afterwards I use the original curve index to transform the list of curves back into their original component groupings and so I can re-link the component with their labels.
Question:
How do I create this association with HiddenLineDrawing.Compute
? I can see the method returns a HiddenLineDrawing
type where I can access the Segments
class which has an parentCurve
property - would the HiddenLineDrawingObjectCurve.SourceObject
be the equivalent of the Visible Index
output from the Make2D
GH component? I’m finding the connections confusing to grasp…
Otherwise I’m pretty green at working with C# so if anyone has any suggestions/snippets for working with HiddenLineDrawing.Compute
they would be welcomed
Much thanks,
L.
