I’m looking for a problem … I try to group several 3D Line created by my program. Indeed, when i’m creating these lines, in Rhino they are assimilate like 1 object singly, so if you want to move the “Barbule” (That’s my plug-in), you have to move each line One by One, and it’s not recommended.
By my side, i try to use the class GroupTab, however with this class you can just select by yourself, in RhinoApp, objects you want to group. So can we group these lines inside the program with a specific method ?
Hi Dale, you’re right, but i don’t want to group these lines on RhinoApp. I’m looking to group a list of 3D lines for when i’ll launch my plug-in all lines created move as one.
I’m sorry, i’ll try to explain better . In your example, you select many object on Rhino3D (the app)…
And my problem is: how group the line (on my side, 3D line) I’ve created in my program ? Look this example :
In this code, I have one list of Line to trace my “Barbule”, I add these lines one by one. However I want to group them in a single Object. In the goal to manipulate (In Rhino3D) all lines together.
for (int i = 0; i < ptCountMulti; ++i)
// Link the HighLine between them.
Rhino.Geometry.Line line = new Line(firstList[i], secondList[i]);
doc.Objects.AddLine(line, colorMulti);
for (int j = 0; j < nbSmallLine; ++j)
// Link the SmallLine between them.
Vector3d smallVect = new Vector3d(secondSmallList[idxMulti].X - firstSmallList[idxMulti].X, secondSmallList[idxMulti].Y - firstSmallList[idxMulti].Y, secondSmallList[idxMulti].Z - firstSmallList[idxMulti].Z);
Point3d ptSmallFinal = new Point3d(firstSmallList[idxMulti].X + (smallVect.X * lengthSmallLine), firstSmallList[idxMulti].Y + (smallVect.Y * lengthSmallLine), firstSmallList[idxMulti].Z + (smallVect.Z * lengthSmallLine));
Rhino.Geometry.Line smallLine = new Line(firstSmallList[idxMulti], ptSmallFinal);
doc.Objects.AddLine(smallLine, colorMulti);
++idxMulti;
// Draw In RhinoApp
doc.Views.Redraw();
